14 years agoCould not find rtl_work.TB.vhd
Hello, The same process is giving issues once again: # ** Error: (vsim-3170) Could not find 'C:\Users\Alfonso\Desktop\PFC\simulation\modelsim\ rtl_work.TB_PFC_main'.# Error loading design...
14 years ago --- Quote Start --- The VHDL code is trying to use a component compiled into the rtl_work library. You can either compile your code into rtl_work via; vsim> vlib rtl_work vsim> vmap rtl_work [pwd]/rtl_work vsim> vcom -work rtl_work <your VHDL files> --- Quote End --- Hello, by typing this, how do you fill <your vhdl files>, by typing my vhdl files root (C:\Users\Alfonso\Desktop\PFC\altera) returns this: (I typed vsim> vcom -work rtl_work C:\Users\Alfonso\Desktop\PFC\altera) # Model Technology ModelSim ALTERA vcom 10.0c Compiler 2011.09 Sep 21 2011# ** Error: (vcom-7) Failed to open design unit file "C:UsersAlfonsoDesktopPFCltera" in read mode.# Invalid argument. (errno = EINVAL)# E:/altera/11.1sp2/modelsim_ase/win32aloem/vcom failed. --- Quote Start --- or you can simply map the rtl_work library to the same location as the work directory, eg., assuming you have created your work directory in the same folder you are working in via vsim> vlib work vsim> vmap work [pwd]/work then you can tell Modelsim to look in the work directory for the rtl_work components too by mapping it via vsim> vmap rtl_work [pwd]/work (You don't need the [pwd] statement if you don't want to use absolute paths in your .ini or .mpf file). Cheers, Dave --- Quote End --- It did not work, assuming [pwd] is written as [pwd] litterally (if it is a root instead, tell me) after typing those three lines literally as you did it continues returning me: # ** Error: (vsim-3170) Could not find 'C:\Users\Alfonso\Desktop\PFC\simulation\modelsim\rtl_work.TB_PFC_main'.# Error loading design# Error: Error loading design # Pausing macro execution # MACRO ./PFC_run_msim_rtl_vhdl.do PAUSED at line 34 Please help me i cannot test my code till this is solved.
