shaneh_fl
1 year agoConverting Oscillator HCSL Output to SSTL_18
I am designing a PCB with a MAX 10 (10M50DAF256) with DDR2 and the MAX 10 requires a SSTL_18 clock source. I found Renesas AN-891 online and it describes using a HCSL driver, series 0.1uF capacitors ...
AqidAyman_Altera
1 year agoThank you Frank for sharing your input.
With that I wish to follow up, is there any other help or support needed for this issue?
shaneh_fl
1 year agoThanks to all for the inputs for my post. They were very helpful. I am hopeful that my HCSL to SSTL_18 conversion will work. I will find out in a month or two. If the MAX 10 does not like it, I can use a generated 100MHz PLL to source the DDR2 IP which is good insurance.
