17 years agoConverting DE2 Design to a CIII Board?
I am trying to convert a project designed for a DE2 board to a CIII DSP Board (EP3C120) This entails modifying the design to use DDR2 memory instead of SDRAM. Before I give myself a crash cour...
17 years agoYou should change pins very correctly from cyclone II(DE) to cyclone III .USE pin maps of both cyclone devices (voltage and names).Create new pins map and load it into your Quartus project. It's routine but very important because altera's tutorial warned that pins connected in wrong way can burn circuit.
