15 years agoConversion uses all combinational logic
Hi, I'm having trouble converting from an integer to an 8 bit std_logic_vector. It complies and gives an error that all my combinational logic nodes are used. I'm using a cyclone II FPGA chip. ...
15 years agoTo understand about the problems involved by your design, you can do like this:
Compile the design without a particular FPGA selected. e.g. Cyclone III, auto device selection. Then browse the Resource Utilization by Entity category in Compilation report/Analysis and synthesis. You'll notice, that most of the 18k LEs is consumed by the various large dividers in your design (including mod operations, which also uses dividers). Parallel dividers have a huge resource utilzation and should be avoided, if possible. This is a kind of design that's not well suited for FPGA implementation. There are surely options to reduce the resource usage. Implementing slow serial dividers would be an obvious one.
