14 years agoControl internal module ports during Quartus build
I have an IP from external vendor. This IP has additional input ports which are needed and needs to be controlled in FPGA only (enabled by `ifdef FPGA). But the digital wrapper of this IP does not have these input ports. How can I control these inputs of the IP without modifying the wrapper during Quartus FPGA build (synthesis)? Can we do assign to the IP inputs during synthesis? eg: module IP_ext ( `ifdef FPGA input fpga_clk, input fpga_rst, `endif input data_in, output data_out ); module wrapper ( input data_in, output data_out ); IP_ext u_IP_ext ( .data_in (data_in), .data_out (data_out) endmodule I want to control 'fpga_clk' and 'fpga_rst' of IP_ext from the toplevel which instantiates the wrapper module while doing FPGA compilation such that these ports are connected correctly in FPGA. How can I achieve this? Note that wrapper module does not have these 2 ports and we are not supposed to edit the wrapper RTL. Kindly help. Regards, SubyNo RepliesBe the first to reply
