17 years agoConstraints from LVDS blocks and logic
Hi, I have a lvds tx and rx blocks in a Stratix3. There a 20 bits with deserialisation factor of 4. With the Rx side, the data leaving the lvds is registered. The lvds and registers are using c...
17 years agoI have no problem using TimingQuest but at the place I work they use TAN. With my designs, I use TimingQuest but the main build of the design still used TAN. Just on a side note, MC constraints are built-in to the lvds blocks, so I don't have to add them in TimingQuest or TAN? I do remember when I selected to use an external PLL for the lvds, a message appears that I had to add constraints manually from lvds block to registers. Is this still valid or is this for TAN only?
It does look like we have a skew problem, something that doesn't appear with this design in the STX3 150 part. I've set it to run with the derive_clock_uncertainty. Not sure if there any other lvds constraints that we need to have. I've seen stuff about rskm, tccs etc. Not sure if this applies here.
