17 years agoConstraints from LVDS blocks and logic
Hi, I have a lvds tx and rx blocks in a Stratix3. There a 20 bits with deserialisation factor of 4. With the Rx side, the data leaving the lvds is registered. The lvds and registers are using c...
17 years agoIf the constraints are already there, then you shouldn't be adding constraints(they need to be added in the case where they're not added). Anyway, rather than go back and forth, create a quick schematic/HDL file with the LVDS block coming in, feeding some registers and going out, or something like that, the PLL(if you instantiate one) and the .sdc file that reflects what you have, archive it and attach it. I generally don't look at designs(not enough time), but it should only take a minute or two and faster than posts asking questions.
