17 years agoConstraints from LVDS blocks and logic
Hi, I have a lvds tx and rx blocks in a Stratix3. There a 20 bits with deserialisation factor of 4. With the Rx side, the data leaving the lvds is registered. The lvds and registers are using c...
17 years agoAnother thing I've noticed is that even though it says 'Multicyle-Hold Start 3' in the path summary section, it says in the waveform window of 'TimingQuest', "No Hold Multicycle Exceptions/No Exceptions" which seems to suggest that there are hold execptions despite what's in the path summary window.
I also found that if I set a multicyle hold constraint of 3 between the failing paths, it doesn't work but if I do the constrain between the two clocks, then it seems to work fine. So, I don't know if there is something missing here regarding the hold constraint that should have been in or hasn't been picked up correctly. MT
