17 years agoConstraints from LVDS blocks and logic
Hi, I have a lvds tx and rx blocks in a Stratix3. There a 20 bits with deserialisation factor of 4. With the Rx side, the data leaving the lvds is registered. The lvds and registers are using c...
17 years agoI've tried the all paths settings and it does work, however, when I intergrate this block into the main design (this is just a sub block in a much larger design) some of the paths fail the hold timing. So, I really need to understand this timing problem so that I can put in a fix that doesn't depend on the tools delaying the signals.
Any help would be most appreciated. Thanks MT
