17 years agoConstraints from LVDS blocks and logic
Hi, I have a lvds tx and rx blocks in a Stratix3. There a 20 bits with deserialisation factor of 4. With the Rx side, the data leaving the lvds is registered. The lvds and registers are using c...
17 years agoIt's probably talking about MCs for the Classic Timing Analyzer(which behind the scenes would add a hold multicycle). For the most part, a setup mc of 2 in classic would be done by a setup MC of 2 and hold MC of 1 in TimeQuest. Or more exactly, a setup of N in Classic is a setup MC of N and a hold MC of N-1 in TimeQuest.
(Although if you're phase-shifting your clock, that may not be accurate, since Classic TAN did a thing called normalization. For whatever MCs you add, I would explicitly do a report_timing -setup and -hold on those paths and make sure the setup and hold requirement is what you expect.)
