12 years agoConstraints for inverted clocks
The task looks simple, but I don’t know which constrain to use. I have to output two signals (200 MHz clocks) from FPGA. First is an inversion of the second: Mem_ClkP <= Clk; Mem_ClkN <=...
12 years agoThank you.
But I am not designing a real device. I'm just learning constraints. Everything you suggest will work, of course, but I want to play with timequest and fitter, setting different phase deviations. If there is no such constraint, I`ll stop thinking about that.
