9 years agoConstraining source syncronous output
Hi all, I'm trying to understand the constraining of source synchronous interfaces. I am a little bit confused. Let’s say we have an interface to an external SDR SDRAM device. The latch clock f...
9 years ago --- Quote Start --- So why we talk about a delay equal to the setup_time? Why they don't call it an earliness or something like that? Since the Output has to be ready a specific time before the clock edge. --- Quote End --- set_output_delay max decides the late margin of transition and = tSU of external device assuming no board delay difference of data/clk set_output_delay min decides the early margin of transition and = -tH of external device, with same above assumption it is referred to latch edge while tCO (that decides early/late margin) is referred to launch edge to be more accurate: early margin = - min delay late margin = clock period – max delay
