17 years agoConstraining PLL in TimeQuest
Hello, I was waondering how to use derive_pll_clocks comand in TimeQuset. TimeQuest can't reflect new frequency. I did... 1.I grenarated SDC File from QSF File. 2.I changed input...
17 years agoHi wat_arg,
By default, the PLL clock name is the same as the output pin name. However, in Classic Timing Analyzer, the PLL clock name is the same as the net name. By specifying -use_tan_name option to derive_pll_clocks, you can use the net name as the PLL clock name. For example, when the instance name of the ALTPLL is inst, the c0 clock is set as follows: without -use_tan_name: inst|altpll_component|auto_generated|pll1|clk[0] with -use_tan_name: pll:inst|altpll:altpll_component|pll_altpll:auto_generated|wire_pll1_clk[0]
