10 years agoConnection between Cyclone III with ATXmega or HC series logic device
Hello I'd like to connectCyclone III FPGA with ATXmega, powered with 3.3V (data bus). I have two questions: 1. Can i connect it directly or i have to use resistor or bus transceiver (for e...
10 years agoIf the I/O voltages match, you can connect the ATXMega and Cyclone directly.
The presence of bus transceiver and resistors on the dev kit is most likely a protection measure. If you have a dev kit that is being used for any number of things (some may use the buttons, others not), it is sensible to have series resistors in case somebody configures the FPGA pin connected to the transceiver as an output not an input - in essence to protect against damage due to bus contention (e.g. one end drives high, the other drives low). It may be worth adding resistors between in your design as well for the same reason - protect the FPGA just in case something bad happens.
