12 years agoConnected system ID hash not found on target at expected base address.
Hi, I do get the following error message when I want to download the elf file with the NIOS II Eclipse tooling: Unable to validate connection settings. Connected system ID hash not found ...
12 years agou say that errors appears when u add PIO. It seems that u don't regenerate BSP files. You have to do that. The hardware changes. In my little experience with nios and sopc builder I found if you don't check option "CPU ID" when u add NIOS processor, u can't connect with it when u're trying to download elf file.
