14 years ago
Connect several ALTPLL on a input port signal
Hi
I would like to connect several inputs PLL on the same input port signal. Is it possible?
The frequency input of the ALTPLL is 66MHz.
I obtain a warning
Warning: The parameters of the PLL Clk65MHz: pll1 do not have the same values - hence these PLLs cannot be merged
Info: The values of the parameter "Min Lock Period" do not match for the PLL atoms
--- Quote End ---
    PLLs need to be driven by dedicated clock inputs. The connection capcbilities are different for FPGA families, refer to the clock network chapter in device handbook, or ask specifically.
