8 years agoconnect hps to fpga
Hi, I'm using de-10 standard and I need to connect RX and TX signals to UART, but i need them to connect to FPGA. I know you can connect hps to fpga, but I cannot find any examples for my...
8 years agoHi, I assume your IP is in the FPGA logic, and that this IP will output info via UART protocol to the external world. In this case, you can route the UART IP to the FPGA I/O that is located in the DE10- standard GPIO expansion header, and connect the external two pins (TX, RX) externally.
