10 years agoConnect 4 async SRAMs to FPGA
Hello this is rather a hardware question. I´d like to connect 4 asyncrone SRAM devices (250MHz NoBL Types) to a Cyclone IV FPGA. Each data signal is a point to point connection FPGA to SRAM...
10 years agoThere are two resistors because I want to use one signale set (addr, WEn, OEn, etc.) for two SRAMs. A second signal set is for the other two SRAMs.
So if I have to drive two address lines with one FPGA pin i think there should be one 25ohm resistor in each address line.
