10 years agoConnect 4 async SRAMs to FPGA
Hello this is rather a hardware question. I´d like to connect 4 asyncrone SRAM devices (250MHz NoBL Types) to a Cyclone IV FPGA. Each data signal is a point to point connection FPGA to SRAM...
10 years agoWhy "two 25ohm resistors"? I thought you had four SRAM chips. You would want a resistor in each branch. OCT may or may not help, it's not the same as a resistor in each branch. In any event you can enable/disable the OCT as desired.
