10 years agoConnect 4 async SRAMs to FPGA
Hello this is rather a hardware question. I´d like to connect 4 asyncrone SRAM devices (250MHz NoBL Types) to a Cyclone IV FPGA. Each data signal is a point to point connection FPGA to SRAM...
10 years agoGenerally speaking you would split the traces at the driver end (the FPGA in this case). You could add a series resistor in each branch (at the driving end) for "series" termination. Alternately, you could externally buffer each set of address/clock lines, which adds up to a lot of buffers. At 250Mhz I would certainly buffer each clock signal independently for maximum signal integrity, or you could use four FPGA outputs for clocks. If your clock is generated from a PLL in the FPGA, check the worst case jitter specification which can be quite high.
