16 years agoConfusion on signal attribute HIGH
I have a probleb understanding the attribute HIGH. I googled and I can understand what it means and how it applies to certain cases. But I am trying to figured out an IP and it is essential that I absolutely correctly figure out how HIGH, or what value HIGH returns to understant the process. Basically I have something like this: ARCHITECTURE something OF someotherthing IS CONSTANT constVal : positive := 100; SIGNAL someSignal : unsigned (10 down to 0); .... .... someSignal <= to_unsigned(constVal, someSignal'LENGTH); Now there is a statement: somesignal(somesginal'high) I am a little confused what value it returns here. Some explanation is greatly appreciated. Thank you.4 Replies
Thank you, FvM
Thank you very much FvM, Tricky.
I thought it is so but wasn't sure. Thank you for confirming it with examples. Cheers. - Altera_Forum
the 'high attribute returns either the highest value of a type, or the highest index in an array type:
signal slv0 : std_logic_vector(10 downto 0); signal slv1 : std_logic_vector(3 to 99); subtype myint0 is integer range -10 to 17; subtype myint1 is natural range 18 to 66; type sometype is (A, B, C, D, E); slv0'high = 10 slv1'high = 99 myint0'high = 17 myint1'high = 66 sometype'high = E - Altera_Forum
someSignal(10) (type'high designates the highest index value of a bit vector)
