11 years agoConfiguring Cyclone IV E over serial interface problem
I have a setup in which an MCU is hooked to a Cyclone IV E with two options for configuration. The first option uses a compressed .rbf file saved in the MCU's flash memory and feeds it to the fpga through the Active Serial connection (AS). This works fine. However, the second option goes like this PC -> TCP -> MCU -> AS -> FPGA. I receive packets over TCP with 256 byte long chunks of a decropressed rbf from a PC application. All packets are correctly received by the MCU and retransmitted over the AS to the FPGA. Sadly, this isn't working. The CONF_DONE signal doesn't go high. Here is the code for the first option (just for comparison)void fpgaConfig(void){
int i;
int length;
uint16_t temp;
spiDAT1_t dataConfig;
uint32 PC0Backup;
gioSetBit(spiPORT1, SPI_PIN_SOMI, 0); // nConfig low
delay(0xffff); // wait
gioSetBit(spiPORT1, SPI_PIN_SOMI, 1); // nConfig high
while(gioGetBit(spiPORT1, SPI_PIN_ENA) == 0); // wait until nStatus is high
PC0Backup = spiREG1->PC0;
spiSetFunctional(spiREG1, PC0Backup | (1U << SPI_PIN_SOMI)); // set nCONFIG as SPI pin
dataConfig.CSNR = 0;
dataConfig.CS_HOLD = 0;
dataConfig.DFSEL = SPI_FMT_0;
dataConfig.WDEL = 0;
length = sizeof(designData);
for(i = 0; i < length; i++)
temp = designData;
spiTransmitData(spiREG1, &dataConfig, 1, &temp);
delay(0xfffff); // wait
while(gioGetBit(spiPORT2, SPI_PIN_CLK) == 0); // wait until CONF_DONE is high
while(gioGetBit(gioPORTB, 7) == 0); // wait until INIT_DONE is high
spiSetFunctional(spiREG1, PC0Backup); // put back the original value. This is important to make reconfiguration possible
} And here are the important parts of the second way:
case SEND_FPGA_DESIGN_START: {
if (state == PAIRED)
receivingFpgaDesign = 1;
totalDesignSize = *((uint32 *)(&cmd.data));
packetsRemaining = *((uint16 *)(&cmd.data));
xSemaphoreTake(tcpSendProtection, portMAX_DELAY);//The mutex is freed in the server_sent callback
txBuffer = (uint8)FPGA_DESIGN_CONFIRMATION;
tcp_write(cmd.pcb, txBuffer, MINIMUM_PAYLOAD_LENGTH, 0);
tcp_output(cmd.pcb);
else
state_machine_error();
break;
case SEND_FPGA_DESIGN_DATA:
if (state == PAIRED && receivingFpgaDesign)
uint16 currentOrdinal = *((uint16 *)(&cmd.data));
if (currentOrdinal == 1) //This could also be in the previous CASE
PC0BackupValue = spiREG1->PC0;
spiSetFunctional(spiREG1, PC0BackupValue | (1U << SPI_PIN_SOMI)); // set nCONFIG as SPI pin
if (currentOrdinal == lastOrdinal + 1)
lastOrdinal++;
if (packetsRemaining > 1)
int i;
uint16 temp;
for(i = 0; i < 256; i++)
temp = cmd.data;
packetsRemaining--;
else //this was the last one
int i;
uint16 temp;
int upperBound = (totalDesignSize % 256) == 0 ? 256 : totalDesignSize % 256;
for(i = 0; i < upperBound; i++)
temp = cmd.data;
while(gioGetBit(spiPORT2, SPI_PIN_CLK) == 0); // HERE IT GETS STUCK
spiSetFunctional(spiREG1, PC0BackupValue); // put back the original value. This is important to make reconfiguration possible
As you can see the second option is just like the first one only the data arrives in chunks. Any ideas what the problem with the second one might be? I'm really at a loss now. I'd appreciate any help.2 Replies
Try reading back the portion of flash used for FPGA configuration in the working setup. Compare this to the data file you are sending using the MCU. There might be additional headers, byte swapping, checksums, etc that change the data as it is being programmed in flash.
Thank you,
you were right. The data isn't the same. Now I must figure out how it got corrupted. Thanks again!
