17 years agoConfiguring Altera devices on long-distance cabling
Hello, We have a need to configure Altera devices (EPC configuration devices and some FPGAs) through a long cable (~ 3 m). For the sake of simplicity let's say that the setup is a PC, 3 m of c...
17 years ago --- Quote Start --- I understood pretty good what's your problem. The JTAG side connection can't be simply extended. As you gave not a single reason, why you didn't consider to extend the USB side, I just reported my solution for a similar problem. In other words: When extending the JTAG interface (with acceptable speed), there must be a driver near to the board connector. Why not using the USB Blaster as the driver? --- Quote End --- The board is buried rather deep inside a large case full with other boards. The configuration lines were taken through the motherboard to the connector of the case. Besides, the USB blaster is planned to be made a part of a special test equipment that connects to the case through a proprietary connector, and we want to lead the configuration lines through this connector. The total distance can reach a few meters.
