17 years agoConfiguring Altera devices on long-distance cabling
Hello, We have a need to configure Altera devices (EPC configuration devices and some FPGAs) through a long cable (~ 3 m). For the sake of simplicity let's say that the setup is a PC, 3 m of c...
17 years agoI understood pretty good what's your problem. The JTAG side connection can't be simply extended. As you gave not a single reason, why you didn't consider to extend the USB side, I just reported my solution for a similar problem.
In other words: When extending the JTAG interface (with acceptable speed), there must be a driver near to the board connector. Why not using the USB Blaster as the driver?
