14 years agoConfigure one FPGA from another with a PFL
I started with an existing VXI/VME module design where a MAX II is used as the Backplane interface and configures the FPGA on the board from a parallel flash using the PFL megafunction. In this...
14 years agoI had a similar issue with PFL, so wrote my own controllers. These designs are documented here:
http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf Cheers, Dave
