14 years agoConfigure one FPGA from another with a PFL
I started with an existing VXI/VME module design where a MAX II is used as the Backplane interface and configures the FPGA on the board from a parallel flash using the PFL megafunction. In this...
14 years agoAlright, I am still looking for that easy out. However, I could write my own. I believe I just need to
1. request the bus the Flash is on. 2. get a permit for the bus. 3. read the flash to a FIFO (8x32 deep) 4. serialize the data and clock it over also 5. i need to do the right thing with nCONFIG, nSTATUS, and CONF_nDONE. 6. store the Flash memory page number that I put the config file in. 7. ignore use of burst mode when reading Flash. I do not need speed. It would be helpful if you could point me at the best format for the compiled data and a timing diagram (Passive Serial). What do you think?
