18 years agoConfiguration Problem!
After configuration, can the user logic access the configuration device, EPCS64 for example, through the configuration pins? If can, how to do that? Use a IPcore or user defined logic? Thanks!
18 years agoYou can also specify a memory initalization file for the on-chip RAM or ROM in SOPC builder for the instruction memory to boot right from on-chip memory.
