SLeit's avatar
SLeit
7 years ago
Configuration problem under low temperature at 10M04SAE144I7G
the Configuration work well at room temperature
when we goes down to 10 Celsius degree and down to - 20 Celsius and turn on the board voltage the device no get the configuration
  • SLeit's avatar
    SLeit
    Dear YL
    it is urgent
    please try to help with this problem ASAP
    Shraga
  • SLeit's avatar
    SLeit
    Dear YL
    It is very strange, it is working from +40 to -30 degree
    the main problem is that unter 10 degree when we turn OFF the power and ON again the Altera not working
    so we cant power up at low temperature.
    is it problem of device or pin configuration ?
    Shraga.
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    Hi Shraga,
    If it is working under normal temperature but not cold temperature (-20 C), the connection and schematic should be correct.
    Also, have you probed and observed the configuration pin on MAX 10?
    ERMA is a process for us to perform failure analysis.
    YL
  • SLeit's avatar
    SLeit
    Hello YL
    can i send the schematic for review maybe i did something wrong ?
  • SLeit's avatar
    SLeit
    Hן YL
    we have the same problem in all the boards
    What is ERMA?
    Shraga
    YuanLi_S_Intel
    Hi Shraga Leitner,
    This is weird. May I know how many unit is having this issue? Do you want to proceed for ERMA?
    YL
