SLeit
7 years agoConfiguration problem under low temperature at 10M04SAE144I7G
the Configuration work well at room temperature when we goes down to 10 Celsius degree and down to - 20 Celsius and turn on the board voltage the device no get the configuration
YuanLi_S_Intel
7 years agoHi Shraga,
If it is working under normal temperature but not cold temperature (-20 C), the connection and schematic should be correct.
Also, have you probed and observed the configuration pin on MAX 10?
ERMA is a process for us to perform failure analysis.
YL
