User1591281943159653
6 years agoConfiguration issue between EPCS64 and FPGA
Hello, I am trying to flash program the EPCS64 with Quartus Iii 12.1 version and stratix III and I get this error, EPCS signature is 0XFF EPCS device doesn't support RDID command EPCS identifier a...
YuanLi_S_Intel
6 years agoHi Shwetha,
By seeing at the error message, it seems like the device OPN is not selected correctly in Quartus. Also, you will need to select the correct configuration scheme in Quartus.
If it is due to device problem, can you try to replace it with another device and test?
Thank You
