Configuration issue between EPCS64 and FPGA
Hi Bruce,
Yes, I am able to program EPCS with pof the FPGA is not getting booted from flash. When I try to program using nios II flash programmer I get the error as mentioned in the question. I also tried programming using jic file and I get the error
"can't recognize silicon ID for device 1".
I am using active serial configuration.
Thank you.
On debugging the issue I got to know that there was short between FPGA_DCLK and GND with an impedence of 25 ohms. So I had xray inspection done on the BGA of fpga to see if there were any shorts. It looked fine. So, the only element left is FPGA. Has this pin of FPGA gone bad? If yes, what might be the reason?Should I have to replace the FPGA?
Can someone please help me out with this. I am stuck since many days. Thanks in advance.
