TOYORN
3 years agoConfiguration device for cycloneⅲ
Hello, We are currently using the following FPGAs and SPI-flash device. FPGA:EP3C5F256C8N Configuration device:EPCQ4ASI8N we want to use Winbond W25X40CLSNIG as a replacement for EPCQ4ASI8N. Bot...
WZ2
3 years agoIs it successful to program? If you system run in the user mode, you don't need to warry about it. I just curious the reason why it can program the flash successful because of the difference between the flash ID.
- TOYORN3 years ago
Programming is successful with AS programming.
Thank you for all your advice.
I found that it seems to be usable without problems with Winbond.
