TOYORN
3 years agoConfiguration device for cycloneⅲ
Hello, We are currently using the following FPGAs and SPI-flash device. FPGA:EP3C5F256C8N Configuration device:EPCQ4ASI8N we want to use Winbond W25X40CLSNIG as a replacement for EPCQ4ASI8N. Bot...
FvM
3 years agoHi,
"EPCS4" is in the file because it's generated for EPCS4.
Seriously I don't fully understand your question. You have sucessfully verified programming and configuration operation with W25X40 and are asking if it can be really used?
According to my experience Winbond serial flash are fully compatible to Intel devices for AS configuration. In some cases, it might be necessary to disable ID check in .jic file generation. With direct AS programming, the only relevant criterion is that the programmer programs and verifies the configuration file.
Frank
