TOYORN
3 years agoConfiguration device for cycloneⅲ
Hello, We are currently using the following FPGAs and SPI-flash device. FPGA:EP3C5F256C8N Configuration device:EPCQ4ASI8N we want to use Winbond W25X40CLSNIG as a replacement for EPCQ4ASI8N. Bot...
WZ2
3 years agoHi there,
We have never tried W25X40 on Cyclone III before, but theoretically, the commands between these two flashes should be compatible. However, I need to confirm with you again, whether the successful configuration and boot described in your test were done using the new Flash template to generate the .jic file?
WZ
TOYORN
3 years agoThank you for answering.
We are programming a .pof file, not a .jic file.
This is not a newly created file, it is the same file that has been programmed in EPCQ so far.
It still shows "EPCS4" on Quartus II 13.1 programmer.
