VKadl
7 years agoConfig. flash production programming
We are in the final development phase of our product, where we use Intel Arria 10 10AX048H4F34E3SG + Micron MT25QU512A as config. Flash for FPGA. We have encountered the problem with programming of ...
ShafiqY_Intel
7 years agoHi VKadl,
Yes, configuration register of the micron device is slightly different from EPCQ.
You may need to program bin file with correct configuration setting.
Thanks😉
- VKadl7 years ago
Is there correct configuration somewhere? Because I have programmed 3 Micron flash via JTAG using .jic files and when I read config register settings, I got 3 different settings, so I don't know which one is correct.
For example:
