Hello, FvM!
Recently I asked:
--- Quote Start ---
How much time will it take to load the content of EPCS4 into FPGA if payload is only ~2Mbit and the rest is filled up with 0xff ?
The case is that EP4CGX22 is in "40 Mhz internal oscillator mode".
There are to possible versions:
1). 4,000,000 bits x 25 ns / 1 bit = 100 ms
2). ~2,000,000 bits x 25 ns / 1 bit = ~50 ms
25 ns = 1/40MHz.
Which one is correct?
P.S. How to calculate decompression time by EP4CGX22?
--- Quote End ---
And You answered:
--- Quote Start ---
The latter is right, configuration bitstream load stops after the real data and a few terminating '1' s.
--- Quote End ---
Can You please give me any reference to Altera documents where I can find a straight-forward statement, that "configuration bitstream load stops after the real data" and the configuration time is calculated by taking into account only the "real data" ( or payload ) size of .jic file ( which can be seen in the corresponding .map file as END ADDRESS )?
