17 years agoConf_Done stays low after programming
Hi, I have a design on Cyclone III EP3C120F480C7 that works pretty well when the input clock frequency is low, but quits working when the frequency increases. The reason it quits working is bec...
17 years agoI am trying to program an EPCS4 from an Altera USB Byteblaster, in circuit. I can program the image store, but the Cyclone II C20 device doesn't release conf_done at the end of programming although nCONFIG is going high. (This is ASP not JTAG)
What appears to be happening is that the USB-Blaster is holding the clock line low, and doesn't tri-state it after programming. The Cyclone tries to load the image but can't clock data from the EPCS4. It works fine if I manually disconnect the clock pin from the Blaster then reconnect it. I need to keep the Blaster connected, so I'm looking at adding some electronics to disconnect the signal :-( Didn't see this on a Byteblaster II, but I don't have one to hand to investigate. It may be that the USB blaster can sink more current, or the BBII (again Altera) might tri-state the line. Looking at the clock line with a scope shows lots of spiky, noisy clocks with very slow rise and fall times when both devices are connected. Anyone know of a way to make the USB Blaster release the line? Malcolm
