15 years agoconcatenation on wire
Hi all, I did a simple experiments regarding concatenation on wire, below is the verilog code. // file : le_count_experiment.v // date : 17 dec 2010 // author : ty6 // to experiment ...
15 years ago --- Quote Start --- means that reg_in, in1 and in2 must be same width? --- Quote End --- No it's not required. I thought, it would be the case, because VHDL wouldn't allow this assignment, Verilog however does. But the explanation is much easier. In1 is simply assigned to the part of reg_in, that's never read. You have to double the width of reg_out to see the in1 data. I'm not absolutely sure, if you know, what a concatenation is? With DATA_WIDTH = 4, it creates a bit-vector of length 8. If you only read the lower 4 bits, in1 is ignored.
