8 years ago
Computer configuration for FPGA compilation
Hi everyone,
I have to change the computer which I use to work on FPGAs becauase It needs 2 hours and half to compile a complex Arria V code . I have a doubt about two configuration: the first one based on I7 8700K and the second based on I9 7940X, equipped with 64GB DDR4 and SSD, both.
I7 has 6 cores, 12 MB cache and works up to 4.7 GHz.
I9 has 14 cores, 19,25 MB cache and works up to 4.3 GHz.
Quartus 17 is capable to fully load 14 cores or it's better a CPU with 6 cores that work faster than 18?
Any advices???
Thanks in advance.
    Just after submitting my answer I thought of something.... where are you using most of the time when compiling your project? If it is the fitter then it may make sense to go for higher cores, because AFAIK it is the fitter that is currently the most multicore friendly part of the Quartus compiler. You can also monitor your current PC CPU cores usage while to compile your project to check.
    I'd go for the one with lower cores but higher top clock speed. Quartus is getting better with multicores, but is not there yet. I'm not sure the cache size increase is enough to make a difference.
    For others that might have a similar question about computer configuration I will put this here: I only know RAM is important, and if I remember correctlh 64GB should be enough for Arria, as for cores, I have no idea
