14 years agoCompiling NIOS 3.2 / Quartus 4.2 in Win8
Hello all, We have a legacy system which still uses the Quartus 4.2 and NIOS 3.2 compiler / SOPC builder to compile the firmware. We have no option to upgrade as we are still using the old APEX...
14 years agoDon't bother trying to install old tools in new operating systems. Its not worth your frustration. Install VirtualBox on your Windows 8 machine, and then install Windows XP in VirtualBox followed by Quartus 4.2.
If you are lucky, Windows 8 will allow the USB-Blaster to be captured by the Virtual Machine. Windows 7 would not allow this (at least for my tests). Windows XP and Linux hosts worked ok. If you store the Virtual Machines on a USB hard-drive, then you can boot the VMs on any machine you like (use the "Machine->Add" menu option in Virtual Box, and then remove it when you are done). Cheers, Dave
