12 years agoCompiling FPGAs with QSYS could be annoying. Any plan to overcome this problem?
When you generate a system with QSYS, the generator does not check the VHDL code completely. Then, when you include the generated system into your project, first you have to run the analysis and s...
12 years agoIf you thoroughly test every custom block separately, you only have to generate once, or at least not that often :)
