10 years ago
Compilation step gets very slow with shift register (multiple unrolled shifts)
I just ran into this behaviour when trying to compile an unrolled loop over a shift register.
The code needs an incredible amount of time to get past the compilation step (Altera Offline Compiler on Windows).
-->The compilation step right before the logic - estimation output.
Issuing Code:
# pragma unroll
for(int i = 0; i < NUM_DISPARITIES; ++i)
    ushort sum = 0;
   # pragma unroll
    for(int wx = 0; wx < BM_WINDOW; ++wx)
         sum += abs((left) - (right));
     //shift register
    # pragma unroll
      for (int s = (BM_WINDOW * IMAGE_WIDTH - 1); s > 0; --s)
          linSums = linSums;
     linSums = sum;
'left' and 'right' are also shift registers, the problem was the same with using 'linSums' as a 1-Dimensional shift register.
With NUM_DISPARITIES = 2 the Code needs little more than expected.
At NUM_DISPARITIES = 16 the compilation step needed over 20 mins.
Maybe this isnt a bug, but bad code or misunderstand use of shift registers ^^
However I would appreciate any help!
Steffen
