17 years agocompilation for 163 bits
hi to al! the compilation for 163 bits (2 inputs of 163 bits each and the output is also 163 bits) is not exceeding 2% of full compilation and 9% of analysis and synthesis even when the time ha...
17 years agoI would like to know if the larger 'for' loops are spilt into a number of smaller for loops will that reduce the complexity and resource utilized. Does the function and module concept consumes the same resource.
example: for(k=0;k<652;k=k+1) begin F=F+(u[x]*v[y]); end This loop will be repeated for about 160 times. Kindly explain about this.
