17 years agocompilation for 163 bits
hi to al! the compilation for 163 bits (2 inputs of 163 bits each and the output is also 163 bits) is not exceeding 2% of full compilation and 9% of analysis and synthesis even when the time ha...
17 years agoTo run a loop sequentially, that means feeding the same logic with different data, you have to use a clock and some kind of sequencer or state machine. Otherwise, the FPGA compiler is forced to calculate all iterations in parallel, which is impossible due to limited resources.
