10 years agocomparing arria10 and stratix v fmax for same design
hi, i have a RTL design which I map to arrai10 and stratix V fpgas. i synthesize the design in synplify_premier for arria10 and stratixV (using the exact same synth settings) and transfer the...
10 years agoI would always ask questions of code that one tool understands and another doesn't. I might ask if it should be re-written. However, given the error message - when synthesising with Quartus, are you specifying the right verilog version for your code? Forgive me if it's written in VHDL, but the same applies. Are you simply using a newer language construct that Quartus isn't set to understand. Check what version of the language you've set Quartus to use: 'Assignments' -> 'Settings' -> 'VHDL/Verilog HDL Input' catagories.
I've just finished another reference design run. This time Arria 10's Fmax is a good 5% grater than Stratix V. Cheers, Alex
