14 years ago
comparator with memory
I'm starting with vhdl, and i'm try to write any kind of comaprator with memory of the out signal.
Can anyboidy help me..
Program have to check state of input from keypad (ps2) and check it is signal of a letter. if pressed keypad is a letter then on the out will be signal of these key
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY bufor IS
PORT(in: IN STD_LOGIC_VECTOR (21 downto 0);
out: OUT STD_LOGIC_VECTOR (7 downto 0));
END ENTITY;
ARCHITECTURE mem OF bufor IS
shared variable li1 : std_logic_vector(7 downto 0);
shared variable li2 : std_logic_vector(7 downto 0);
BEGIN
process (in) is
begin
li1 := "00000000";
li2 := "00000000";
li1 := in(8 downto 1);
-- checking of keypad key
if (((li2) /= (li1))and (li1=( X"21" OR X"23" OR X"24" OR X"2B" OR X"34" OR X"33" OR X"43" OR X"3B" OR X"42" OR X"4B" OR X"3A" OR X"31" OR X"44" OR X"4D" OR X"15" OR X"2D" OR X"1B" OR X"2C" OR X"3C" OR X"2A" OR X"1D" OR X"22" OR X"35" OR X"1A"))) then
li2 := li1;
end if;
out <= li2;
end process;
end mem;
    --- Quote Start ---
    when the input signal isn't signal of keypad i have 0 ont the out...
    --- Quote End ---
    That's correct. The process you wrote indeed makes this.
    Infact every time the process runs (when 'in' changes), you assign
    li1 := "00000000";
    li2 := "00000000";
    then, whenever the 'if' condition is not fulfilled (namely when signal is not from keypad)
    your output keeps this zero status.
    If your code is supposed to hold the last keypad code on 'out' as long as a non-keypad code is received, simply remove these 2 lines.
    Cris72 i've fixed that :) you're BIG :) now i have a little problem, beacouse when the input signal isn't signal of keypad i have 0 ont the out...
    Sorry for my english ;]
    The OR chain you wrote is not correct; it will reduce in a
    ((li2) /= (li1)) and (li1 = X"7F")
    condition, since you are logically ORing the 8bit codes of keys.
    You should write:
    ... (li1 = X"21") OR (li1 = X"23") OR (li1 = X"24") OR ....
