9 years ago
communication using rs232 to pc
hi,
i am using an cyclone 5 soc development kit. i programmed fpga and design is running fine. my result is storing in an 45 bit register in fpga @ of 200 hz. i need to transfer these values to my pc. ( i am using quartus)
so i decided to use an rs232 uart from quartus & embedded command shell as software in pc. but problem is there is no user manual for this rs 232 ip.so can anybody please help me on this, how to use this rs-2332 ip (any document or demo program )?
any help is really appriciated :)
// unnamed.v
// Generated using ACDS version 16.0 211
`timescale 1 ps / 1 ps
module unnamed (
        input  wire        address,    // avalon_rs232_slave.address
        input  wire        chipselect, //                   .chipselect
        input  wire   byteenable, //                   .byteenable
        input  wire        read,       //                   .read
        input  wire        write,      //                   .write
        input  wire  writedata,  //                   .writedata
        output wire  readdata,   //                   .readdata
        input  wire        clk,        //                clk.clk
        input  wire        UART_RXD,   // external_interface.RXD
        output wire        UART_TXD,   //                   .TXD
        output wire        irq,        //          interrupt.irq
        input  wire        reset       //              reset.reset
    unnamed_rs232_0 rs232_0 (
        .clk        (clk),        //                clk.clk
        .reset      (reset),      //              reset.reset
        .address    (address),    // avalon_rs232_slave.address
        .chipselect (chipselect), //                   .chipselect
        .byteenable (byteenable), //                   .byteenable
        .read       (read),       //                   .read
        .write      (write),      //                   .write
        .writedata  (writedata),  //                   .writedata
        .readdata   (readdata),   //                   .readdata
        .irq        (irq),        //          interrupt.irq
        .UART_RXD   (UART_RXD),   // external_interface.export
        .UART_TXD   (UART_TXD)    //                   .export
endmodule
above one is the uart ip module, in this they didnt provide any information regarding all signals lke chipselect,byteenable,read,write....
one more doubt is :: is this the correct way of doing this?
inside my fpga there is arm processor. anybody here knows how to do this please share some information about it :)
thanks and regards
