8 years agoCombining pins to source / sink more current
Hi, I have a Cyclone V that needs to be able to briefly source and sink current ~60mA for 1 to 8us before returning to the microamps range. I see that the IO pin max ratings are -25mA to 40mA....
8 years agoIt is difficult to guarantee that the current will be split evenly between the two pins. You could end up with more current on one pin than on the other. Check also if there is a limit on the full I/O bank current.
I think it would be more reliable to use an external buffer or a little transistor to do the job.
