HSteg
6 years agoCombining Active Serial and JTAG for Configuration
Chapter 8 of the Configuration Handbook describes combining different configuration schemes. In the section that describes combining AS (Active Serial) mode and JTAG mode, this chapter indicates the ...
- 6 years ago
Thank you for your clarification. For your question, yes it can be. However, you will need to use different bitstream for that. To program the flash device, you will need to generate JIC programming file. To program FPGA, you will need to generate SOF programming file for that.
YuanLi_S_Intel
6 years agoSorry, before we get started. May i know which device are you referring to?
HSteg
6 years agoHi YuanLi,
I'm referring to a Arria II GX device (EP2AGX65CU17I3G).
Hal
