13 years agoCode Not Running (Adding Tightly Coupled Instruction & Data Memory)
Dear Friend's, I have added Tightly coupled instruction and data memory and then-after my Code won't run, there is no activity on eclipse console. Attached is my sopc and Code. kaush...
13 years agoFrom your bsp I see you are actually not using TCM in your project; everything is still in ddr2. So your code stopped working after you simply added TCM ports.
At first glance I can't see any flaw in the design itself. Did you check if the extra resources requested from fpga caused gave rise to any timing problems?
